alex perini
Active Member
What can I fill the dimples on my 440 pan with so I can use a mr gasket windage tray with rubber gasket ?
It's one of them gasket tray combos with rubber sealYou sandwich the windage tray between two gaskets.
Agree, if you are talking about the small ripples side to side the gaskets cover that. Any windage pan requires two gaskets period. One above and one below the windage tray.
This windage tray has two rubber seals on both sides but says it's for flat surface oil pans
