NIB Crane 690221 Hydraulic flat tappet camshaft. This is a rowdy little grind that will go really well in a mild 340 or 360 or if you wanna walk on the wild side a 318. Production date of 05-13-2014. This has been coated in P'Blaster and wrapped in paper on the shelf. Spray it off with brake cleaner, dry it off and it's ready to go. Cam card and all. Located in Middle Georgia
SPECS:
.504/.504 lift
Advertised Duration 304*
.050" Duration 232*
LSA 106*
Summit has it for $237 bucks here:
Crane Hydraulic Flat Tappet Camshafts 690221
You can have it for $175 shipped to your door in the lower 48.
SPECS:
.504/.504 lift
.050" Duration 232*
LSA 106*
