Duster
Thank you for the info I will rethink that over.
Robert
Robert
if there is anyone on this forum I trust when it comes to suspension stuff, its @72bluNbluThank you for the info I will rethink that over.
Robert
Robert
the amount of suspension travel you are left with, I would be willing to guess it would effect other things as well.
The problem that I see is that in some cases, additional suspension travel could mean that vital underbody parts will now get closer to the pavement as the suspension compresses.
Not good.
Imagine even with a stock oil pan...when you are running down a poorly maintained road, suspension going up and down. If you hit the brakes JUST as the suspension compresses, the K member hits the ground, the exhaust, the tires hit the fenders, etc.
Magnum force and PST are the same. It's a casting instead or a forging but seems a bit safer than the fatman part.yeah, stay away from Magnumn force. Not a big fan based on what's been posted about failures. PST is good and even gives a FABO discount to members as well.
@72bluNblu, the car with the 1.12" bars, is the rear lowered and how?
those sliders make much noise? or just not enough for you to care![]()
Well, all I can really say is that I can’t hear them over the dynomax ultra-flows.![]()
