lilfontleroy
annoyinglilLeroy
last time I checked they only had the one piece for the LA360 - goo up those corners but good!!
I like the milodon crush proof gaskets. They seem to work well for me.
I'm interested in that one piece gasket from jegs... are you certain that is for an LA motor and not a magnum? Reading the comments on jegs one guy was having issues fitting an LA oil pan.
Do you have a link to that gasket? I could only find the Milodon Magnum 1 piece...
On the JEGS website it differentiates the Magnum from the LA.
The LA is described as: JEGS One-Piece Oil Pan Gasket 1970-1990 Small Block Chrysler 360
And linked here: JEGS 210495: One-Piece Oil Pan Gasket 1970-1990 Small Block Chrysler 360 | JEGS
The Magnum is described as: Milodon One-Piece Oil Pan Gasket Chrysler 360
And linked here: Milodon 41007: One-Piece Oil Pan Gasket Chrysler 360 | JEGS
I didn't catch this before, but the LA version is branded a JEGS product. But it looks nearly the same as the Milodon, so I'm guessing Milodon is actually manufacturing … well, both.
I can't vouch for the fact that it really is an LA one piece gasket … but that's what it is advertised as.
