big block
Having trouble with oil pan gasket. Installed a fel pro cork and rubber ends gasket on a la 360 motor today. book says to torque the pan bolts to 15 ft lb. I did my first t tighting to 10 ft lbs and the gaskets squeezed out the sides under the pan IN about 6 places. these were fel pro gaskets but had been siting around for about 6 years. Can gaskets go bad or too much torque on the bolts or ? The pan is 1 of the cheap chrome pans from jegs. any suggestions or anyone got a good oil pan to fit a 360 in a 1974 Plymouth duster for sale? Any suggestions would be greatly appreciated. Thanks
