Bendable Edge Metal
bob7four
New Jersey
Saw a you tube video where they used a bendable strip of metal to replace a lip around a wheel well. Strip had cutouts that had to be welded once shaped. Anyone have an idea where this can be purchased?
I make my own.
Looks easy enough. Did you hand from the Z bend or use a break? Do you trim the table to eliminate any overlap after it is bent?
I used a bench vise for the bends, then a slim cut off wheel in a grinder for the slits.
The outside tabs spread open when you start to make the curve, so I just kept taking more slices out of the inside radius until the proper bend was achieved.
I did the same for a exhaust tube. Slits for clearance and bend, weld up and grind. DIY mandrel bend..sort of.
For exhaust flared bells in tubing, you can heat the end up until red hot & then slowly twist in a trailer ball, which thankfully come in several exhaust tubing IDs.
