Thanks to all the participants..... 2018 small block race
318willrun
Utube channel 318willrun
I'm here
Here are the final standings in the 2018 small block race.
racers 2018.xlsx
Congrats to 65Vsignet, again. Him and I tied for 1st, both going .1 faster than our dial index. I decided "ties" should go to the faster car, because that's what racing is about :)
Again, thanks for all those that joined, had fun, posted, and raced.
318willrun
Thanks for setting this up. I wish I could have made it back to the track 1 more time! I really feel I would have improved my time a lot. Will we be doing this again next season?
Cley
And I was a thousands of a second from standing alone in 1st. :(
LOL...….. :D
11.9 on a 12.0 dial, he's got a quick 318 - enough to take on a 485 hp Scat Pak :)
You are gonna have to step it up next year you cant let him win 3 years in a row!! Lol
What all Is done to his 318?
here is his build post in the race thread.
"1970 318 block, i think its a truck or marine block has 4 mounting tabs for motor mounts, cam is under .500 lift, Eddy heads, and i did upgrade the valve springs this year to trick flow. Crane gold rockers, Eddy RPM air gap intake manifold, and a 650 Brawler Carb. 904 Trans with Dynamic conv around 3200 stall and 4.30 gears in the back."
Just a suggestion but how bout all ties being decided by who has the best reaction time on the posted time slip.
What! I was focusing on my brake torque technique and getting it "just perfect" so I didn't break the 1 leg loose!!! Reaction time was the furthest thing from my mind!! :eek:
Maybe this year I’ll actually make it to the track. I need to tune my car better, I think my timing is off cause it doesn’t have the power it should
17th of 24!! Not too bad for someone who’s never been down a drag strip before!!
:lol:
LOL.... well, anyone that didn't make a pass didn't place... :D Just had to put the participants on the spreadsheet, in no particular order. Order was placed as passes were made. but you knew that.....
318Will. Could you set up a 1/8 mile race for this year?
there was another member that PM'd me about the small block race for 2019. I told him he could use my spread sheets and modify how he seemed fit. He seemed interested in running it this year. I think I'm going to let someone else run it.
Besides, I have a race(s) with Jaba :D
