Deucemopar
Cool!
Thanks.Cool!
I looked at my reply and I believe I should clarify. The reason I'll be able to fit a 30" tire is not just because of the mini tub, but because I moved the rear axle back approximately 1.5".looking good so far. how big of a tire can you fit with the tub done that way?
Love seeing this work going on , looking forward to learning more as this build moves forward
Thanks Mike.I want to jump in here and say thanks again for the show and tell you are taking the time to do hereLove seeing this work going on , looking forward to learning more as this build moves forward
awesome. thanks for that info.I looked at my reply and I believe I should clarify. The reason I'll be able to fit a 30" tire is not just because of the mini tub, but because I moved the rear axle back approximately 1.5".
Thanks. Hopefully your project goes together quicker than mine.Imoressive work. Motivation continues.
For comparison, you are building a rocket,where im building a rowboat. I still like to see what a car like mine can become.![]()
Thanks.This car is going to be bad a$$. Great job keep up the work.
I bought some 3/8" round steel stock so I could make some longer dowel pins, long enough to extend from the T56 all the way through the adapter plate and into the scattershield. I'll have to buy some longer Grade 8 hardware to attach it all together for the final install.
I still may end up doing that later, if I can't get the floor like I want it, but we'll see. The biggest goal for now was making room for moving forward with the crossmember fabrication. I'll worry about cosmetics later.Yikes! I know the t56 is big...but wow.I guess what your doing is really nothing compared to other who build an entirely new trans tunnel.
