Come on Goodmark!
daves66valiant
68 Dart 340/727:66 Signet Vert 340/5spd: 68 D100
SoCal
Battery tray is jacked. Not even close. Funky pinches and causes tray not to line up. BFH I guess is the solution. Anyone else have this issue? May as well use my original. It’s in decent shape.
I have a goodmark, it fits decent with no BFH work. Must have been a defective one. Send it back.
What was wrong with the original?
Minor pitting. I’d already stripped and painted it and thought I got a good deal on this Goodmark one from Summit. Going to use original and return this POS
Take your original if its just lightly pitted, get it sandblasted, then coated with rhino liner. I had my truck bed spray liner coated a few months back, and asked them if they i could throw in 2 battery trays with the deal. They said sure no problem. Just a battery tray, they might charge you $10-$20 and spray it when spraying somebodys truck bed.
Every Good Mark piece I bought, is sitting behind one off my sheds rusting, or cut up and used as a fill pieces in other places than designed.
Plain junk.
AMD.
The AMDs have it.
I mounted the original and it looks fine. You’ll never see the minor pitting because of the battery.
I’m may massage this one real good and spray it with any left over B5 blue I have after I spray my steelies.
You must have just gotten a bad one. Heres the OEM and goodmark i got sprayed with bedliner coating. I believe the oem one is on the right side of the pic.
