Did you use and offset mount adaptor for the brake cylinder or where you able to get by without it on the RB block? Great looking set up, by the way!
I had the stock style on to start with . And no fitment issues. But went to the two bolt set up that doctor diff sells.Did you use and offset mount adaptor for the brake cylinder or where you able to get by without it on the RB block? Great looking set up. by the way!
View attachment 1715271839 My E/SA. Best ET 10.56 at 124
68 Dart owned for 36 years present motor 408 R3 block, 4 inch stroke, Indy 360 -1 heads/ intake, 600 lift cam, TTI 1 7/8 headers, AED 750 hp, 9 1/2 to 1 comp on 93 octane pump gas, 539 hp/ 502 tq , 904 , 4800 stall 8 inch Ultimate converter, 8 3/4 4.30 gear, Hoosier drag radials , 3150 lbs has gone 10.70 @ 124 throttle stopped down to run 11.50s at 114 for 11.50 index and Street Eliminator, 2013 Island Dragway Street Eliminator Track/Points Champion, 2014 Raceway Park 11.50 Index Track/Points Champion
Hey I know that place. LOLNot an a body. 1982 Amc spirit. 408 pump gas small block, 904, A body 8 3/4 3.91s. Been 10.60s.
What's this car run
.030 over 440
906 heads
.509 purple shaft cam
9.75:1 high compression pistons.
9.67@138
You have that car strip down to a 1000 lbs or what ?? Something has to be miss posted here..
What does this car run
Brand new car finished just before winter. Won't know till summer.What does this car run
.View attachment 1715285980 View attachment 1715285981
Here’s mine warring it’s original paint, with 24088 original miles.
