Going on a 76 Volare roadrunner, PO had put on rear 235 x 75 x 15 so size is not important except to be correct and safe for the rim. Will a 245 x 60 or 70 series be OK????
I have 255 60-15's on 15x7's. Pushing the limit but they work A-OKGoing on a 76 Volare roadrunner, PO had put on rear 235 x 75 x 15 so size is not important except to be correct and safe for the rim. Will a 245 x 60 or 70 series be OK????
I have seen that chart before, I have to say it is way conservative.
There's my 7-9" recommendation. That's a better chart.Just look at the tire manufacturer's recommended specifications for the tires you want to run. That chart doesn't list the profile series, so it can't be that accurate. What tire fits on what rim is very dependent on how tall the sidewalls are, the taller the sidewall is the wider the tire can be for a given rim width.
This is for BFG T/A's, according to BFG with the T/A's you could run a 255/60/15 on a 7" wide rim. That may not be true for all tire brands/models, but it would still be in spec for the BFG T/A's. A 245/60/15 would be fine, although a 15x7" is the narrowest rim recommended for those.
I like that rack look, but to a limit! I am considering a side exh like the aar-t cars. These f bodies have a problem in 76 with dual exh and the tank of that yr., so some rake helps that.Mine rides and drives just fine. I didn't have the front end aligned ust put 15's on the back and kept 14's on the front. To properly align mine I would need more positive caster. something Mopars are short on. As long as it drives straight and I can let go of the wheel and it doesn't pull I'm ok. I was going for the look.
Can you spot me $300 for some 8 inch rims!!????? ha . I don't any more in 4 tires a 2 new rims than I have in the entire Volare Roadrunner!!!!!! That ain't hemi Cudas ya know!Fit and correct are two different things. Kids put 205/45/18's on a 10" wide rim with positive offsets so they get them to clear their slammed, overly cambered, stretched fender rice bucket so they can get that deep dish look. If you have room for a wide tire then you have room for a the proper matching and fitting width rim.
