[Found!] Wtb LA sb 360 pushrods
duster731
young gun
Venus Texas
I am replacing my solid lift cam with a hydraulic cam and need pushrods for a sb 360 j heads stock height and crane gold adjustable rockers.. let me know thanks.
Have you used an adjustable pushrod to find out what length pushrod that you need? The reason I say to check the length is because the block may have been decked & the heads may have been surfaced. That with effect the length that you will need, My suggestion is to do it right the first time so you don't have problems later. If you get the length, some here will probably have a set that you can purchase.
Smith brothers. they will make any push rod you need. Remember every push rod is fitted to length needed This changes with Decking other than 9.56 height , Gasket thickness, and Head surface . Always fit new pushrods to a fresh motor or cam change . Unless the used push rods are checked for proper installed length needed and are correct.
