wheelsport
Will I have enough valve clearance if I advance the valve timing 2 degrees on my stock 273?
Stock cam in a std. squeeze 273 You could probably move the cam + or - 8deg w/o worrying.........I'm installing a new timing chain set. While I'm at this point it would be easy to do now so I guess the answer is Yes
