Spindle I D needed
RAT ROD AL
MOPAR ARCHEOLOGIST - one parts hoard at a time!
Lecanto Florida
These spindles came in the bunch of parts I picked awhile back.Can anyone ID them.
The big bolts are to wide for an A body lower ball joint , and the hole is to big for a small upper ball joint.
Some sort of aftermarket stuff but WHAT ? They look pretty heavy duty.
There is no markings on them from manufacturer. Any thoughts? Thanks AL
Those are Fatman drop spindles. The '73 and up UCA and joints should work.
They're actually designed for F-Body (Volare/Aspen or all B, F, J, M-Body vehicles) cars but will work on A-Body's. All stock brake and steering components will bolt right on. The difference between the two is, the F-Body knuckle is about 3/8" taller. There's been a lot of debate over using the taller knuckle but the concerns are largely unfounded. In fact, the geometry is slightly improved under certain conditions according to this article.
