Taz
Member
Hi all,
I am running a four barrel Offenhauser intake manifold with stock exhaust on my 225 ci engine. I had an exhaust leak, so I took the two manifolds into my machine shop to have the manifold to block surfaces machined for better a better seal. Is it possible for this procedure to warp the exhaust manifold? The number 6 exhaust port is now about 1/2" out of line too high and the number 5 about half that, and number 4 a little less.
. What has happened? The other end lines up fine.
