[FOR SALE] 505 stroker and CRT 727
68dodge
Armagh, Pa.
Has a 440 stroked to a 505, 625HP, 653 FT. torque, stroker kit is from 440 source, H-beam rods, platinum series pistons, chevy size H series rod bearing. This motor has 12.4 compression, V-series main bearings, 1/4" main girdle setup, Harland Sharp 1.5 roller rockers 1.5, SFI fluid damper, high torque mini starter, SFI approved flax plate, Hughes 4000 stall convertor, Heads are Edelbrock RPM 75cc fully ported with race valve by Hughe engines, Comp cam roller XR292HR-10 .549-.544, Torquer intake, Quickfuel 1050, MSD Distributor, CRT 727 with Hughes 4000 stall. In pa. $12000
Only 6 runs with 20 street miles. Ran 11.30 so far in a 3520# truck.
Did you already pull this from your truck? If so, did you sell the body?
