68 Coronet RT
68 GTS # 508 in Registry
68 Dart GTS, LS23P8B125038 340 Automatic with Original Fender tag and Build sheet. Sunfire Yellow with a new Black vinyl top and Black interior and new headliner. Front bucket seats are in excellent condition with new foam and the rear seat is in excellent condition. Built September 8th, 1967 at the Hamtramck assembly plant. The engine has a production date of June 22nd, 1967. It is a numbers matching engine with a date correct tranny. The rear is an 8 3/4 posi with 3:55 gears. The engine is a stock block with X heads, with a new Edelbrock RPM intake ( I still have the original ) with a new Edelbrock 650 AVS-2 carb. Stock exhaust manifolds feed 2 1/2 inch TTI pipes with Dynomax mufflers. New direct fit Cold Case radiator ( I still have original ) Brand new BFG radial T/A's Fronts 215/65/15's Rears 235/70/15's mounted on new Scott Drake aluminum mag 500's with 4 1/2 inch bolt pattern. Front brakes are disk with drum rears. Rear suspension has been upgraded to super stock springs ( I still have original springs. More pictures upon request.
$34,900View attachment 1715342292 View attachment 1715342294 View attachment 1715342295 View attachment 1715342298 View attachment 1715342299 View attachment 1715342300 View attachment 1715342301 View attachment 1715342302 View attachment 1715342303 View attachment 1715342304
