BFos
Member
Anyone know the dimensions of a non console shifter handle/stick for a Comp Plus? Can’t find anything on Google.
which? they had a few handle height options.Anyone know the dimensions of a non console shifter handle/stick for a Comp Plus? Can’t find anything on Google.
68 GTS with buckets.Which A body, what year?
It came with a junk Indy shifter so I don’t know what the closest replacement would be. 68 GTS with buckets. Thankswhich? they had a few handle height options.
Yes, originally. Has Hurst Comp Plus now.Did they come w/Inlands?
you probably just want a stock height handle then.It came with a junk Indy shifter so I don’t know what the closest replacement would be. 68 GTS with buckets. Thanks
Which is?you probably just want a stock height handle then.
Brewer's Performance - Mopar A833 4-Speed Transmission and Component SpecialistsGo to brewers, they have repops.
Pic?you are local to me. There is one hanging on my garage wall 150.00 you pick up in topeka
I’ve seen it. Not worth $350. Thanks though.
Pic?
I’ve seen seen them. Not worth $350. Thanks though.Go to brewers, they have repops.
pm sentI’ve seen seen them. Not worth $350. Thanks though.
