It's not just yours...At this point, this car just makes me laugh.
Absolutely nothing has gone together without modifying it, nothing. ie, everything about this car is a pain in the ***. Hahahaha
Did you install the steering chuck on the k-frame while it was out of the car?
I didn't say they are all that easy now did I. Just gave my recent, personal experience with a video on how I did it hoping it might help you. I didn't even put one tiny ding in either. Sorry yours aren't working. I take it you don't want answers or help, so throw more rocks, kick a little and tantrum on my friend!318willrun. I don't care how nice yours went together, it's unrealistic to say they all are that easy.
That's an unfortunate truth. BUT, the torsion bar suspension AIN'T nuthin new. It's been around since what........58....59? HELLO? Plenty of individuals have made nice custom headers on their own. It'd be nice if a header company could do it.
Kinda like how it's unrealistic to say they'll all be as hard as yours.318willrun. I don't care how nice yours went together, it's unrealistic to say they all are that easy.
I suspect quality control on the headers are less than stellar. Can't blame it all on the car.
I agree with everything 72blu posted here. MOA, I'd like to see some pictures (detailed). I understand the frustration. But the max I've heard with Dougs is a small ding or two. If you were close I'd come over and at least try, for a Root Beer because I don't drink alcoholThe problem is, if I made a nice set of custom headers to fit MY car, it wouldn't necessarily fit YOUR car. The headers have to run through an area where 1/4" clearances are generous, on cars that have factory body tolerances of a 1/4" (or more in some places).
Doug's and TTI's both fit some of these cars without modification. There's no way to make a header that will fit ALL of these cars without modification, the production tolerances are just too big.
Exactly. As soon as you start mixing factory with aftermarket you're going to start needing to make modifications. The more you mix factory and aftermarket, and different brands of aftermarket components, the more modifications you're going to have to make to get it all to work together.
Uh, the quality control on those Doug's is way better than the tolerances on these cars.
Ok I purchased these in Aus so I didn't have to pay on the shipping still $650 large as you can see on the pics no matter what I did raise drivers side mount pull steering column away it just didn't cut it, and the amount of area which needed massaging just was an eye sore and I was sick in the stomach with every hit I made. So after looking at a way I could get around this with my work mate we marked out where it needed cutting as I already took measurements on how much clearance was needed. I took it to a friends who runs an exhaust shop and he made the cuts and swapped header tubes 5 and 7 over and brought in the new 7 tube a little closer cut more of the radius & fitted a bung for the 02 sensor $150 dollars for that than took them it for recoating $475.00. Bottom dimples on headers was to provide clearance for the 103 bars. Looks worse in the photos than what they are. Bottom line they fit really well now these mods were made and slide in and out without any issues BUT I needed to pay double to make them work. Every car is different and they weren't the best when manufacted and tolerance's varied from vehicle to vehicle some people have no issues and they fit like a glove some need to make some adjustments for fitment .
I have personally installed 4 sets on 4 different Abodys, and NONE required so much as a ding to clear. What part number are you installing?
I was using the biscuit type than switched to the Schumacher poly mounts which are approx 20mm taller. Pass side fitted like a glove cleared everything .
NO issues.... just installed them on my '76 Duster couple months ago.
