Couple Mistry tools?
j par
Well-hung Member
Portland Oregon
I was given free dibs on some garage sale leftovers and got several tool boxes of tools and some boxes of old stuff. There was a few of the tools I was sure what they were, but there's a couple I couldn't quite make out...??
The one to the right is a thick-a-ma-flick
Can't help on the rest of them, but I'm pretty sure the one to the right of the cardboard box is a fly-tying vise for fly fisherman that make their own. It should have a split end on the tapered upper right part of the gizmo. That holds the hook still while you tie your fly.
The top right hand corner looks extremely familiar I thinks it's some kind of clip or spring installer iv seen one before but cant recall where.
The trianglet are welding clamps, the round thing is a welding ground magnet.
Next is a square spanner. ( think, 4 wheel drive hub nuts)
Then pulling jaws for a slide hammer?
Pistion ring compressor
Next one could be a fly tying vice.
Last ones i cant see good.
Post some better pics.
The one at the bottom right corner is 1870's or 1860's hotdog tongs.
The rest look like dental tools of the same 1800.s vintage. lol
Eff me! Yea a piston ring compressor!! Haha I knew what it did I just didnt know what it did it too! Haha know I feel like a dumbass! I knew I had seen one of them before now I know where!
You sure do know your tools!!
I see a ring groove cleaner, ridge reamer, and a ring expander.
Oh, tool man is right.
Bottom right, ring grove cleaner.
Top right, ring expander. Not compressor.
Witch one os the ridge reemer?
Upper left. The triangular pieces are the shoes that expand into the bore.
The crescent wrench thing is a plumbers tool to remove large nuts off of sink drains, etc.
I see a piston ring expander (used to install rings on piston), a piston ring groove cleaner, and a dial indicator arm.
The plumbers wrench is called a basin wrench, & yes it's used to take the large nuts off of the drain pipe.
the thumbwheel adjustable chrome one in the middle.
also called a spud wrench. light duty version plumbing tool.
main use for me was for the big plastic nut on a toilet tank and larger sink drain nuts.
#20 is the piston ring grove cleaner.
Hold it in your hand and squeeze the point into the ring grove, turn piston.
#21 is still fuzzy or i need glasses?
# 22 is a cam action center force muffler bearing removal tool part number 123456689, not to be confused with the cam action center force CHROME muffler bearing removal tool that had non maring tip, part number, 1g3tfkt.....
