Unassambled short block. The block has been bored .060 with torque plates. Line bored and fitted billet main caps. Crank has been fitted to the block including the bearing clearances set. Has been pararell decked. Balanced probe rotating assambly. Rod bearings fitted to crank also. Rings file fitted to the bores. SFI balancer and sfi flexplate. Cam bearings installed. The block may need to be clearanced for the crank and rods. Block was sonic checked and given a clean bill of health. $6500.00 usd plus shipping. Thanks. Kim. I can get any pics u want.
