[FOR SALE] 543 stroker
oldkimmer
Kindersley, Saskatchewan,
Unassambled short block. The block has been bored .060 with torque plates. Line bored and fitted billet main caps. Crank has been fitted to the block including the bearing clearances set. Has been pararell decked. Balanced probe rotating assambly. Rod bearings fitted to crank also. Rings file fitted to the bores. SFI balancer and sfi flexplate. Cam bearings installed. The block may need to be clearanced for the crank and rods. Block was sonic checked and given a clean bill of health. $6500.00 usd plus shipping. Thanks. Kim. I can get any pics u want.
Unassambled short block. The block has been bored .060 with torque plates. Line bored and fitted billet main caps. Crank has been fitted to the block including the bearing clearances set. Has been pararell decked. Balanced probe rotating assambly. Rod bearings fitted to crank also. Rings file fitted to the bores. SFI balancer and sfi flexplate. Cam bearings installed. The block may need to be clearanced for the crank. Block was sonic checked and given a clean bill of health. $6500.00 usd plus shipping. Thanks. Kim. I can get any pics u want.
SONIC CHECK THE CYL. WALLS ??
Bob, I can’t remember what the guy told me when I picked up the block. He said he wouldn’t of did all the machine work if he didn’t feel it was in the safe zone. I’ll have to find the paper work. Kim
We figured the compression with Indy SR heads, can’t remember the cc of those heads. 11-1 compression. It will be a great pump gas motor. Kim
I do have heads, intake, rockers, Milodon external oiling system among other stuff to basically complete the build, if a guy was interested. Kim
I’m willing to work with someone on shipping, but I can only do so much. I could maybe bring it across the border. Or maybe sell it without the block to make shipping a lot cheaper. But that may or may not make/break the deal. It is good value for what is there. Kim
