Hello, I am looking for a pair of LCA's with tabs in decent shape. Send a PM if you have some. Thanks.
Vancouver area. Send me a PM with some pictures if you can? ThanksWhere in BC are you? I have some up in Smithers.
Sure sounds good. As long as they are not dented up I am interested. I don't mind blasting,painting & changing the bushings. Usual for 50 year old parts..I'll dig some out of the shed tomorrow. I have another set on a scrap 340 Swinger but I'd like to keep that one mobile.
I believe I have a set. Not sure what they came off of.Hello, I am looking for a pair of LCA's with tabs in decent shape. Send a PM if you have some. Thanks.
FYII believe I have a set. Not sure what they came off of.
Thanks for the info.FYI
Randys.
Your's are 73-76 LCA's. with the sway bar mount tab in that location on the arm.
65-72 LCA's with the tab, are welded on low, at the end of the arm, by the ball joint stud location.
