R RAMVAN96 Member Joined Oct 28, 2019 Messages 16 Reaction score 4 Location Wisconsin Rating - 0% 0 0 0 Oct 31, 2019 #1 Contact seller Looking for a dual plane intake for a 5.2/5.9 Magnum. Preferably a MOPAR M1, but let me know what you have.
abdywgn dismantler Joined Jul 30, 2006 Messages 3,714 Reaction score 4,150 Location Darien, Illinois Rating - 100% 5 0 0 Oct 31, 2019 #2 Professional Products 55026: Crosswind Intake Manifold 1500-6500 RPM Range | JEGS
R RAMVAN96 Member Joined Oct 28, 2019 Messages 16 Reaction score 4 Location Wisconsin Rating - 0% 0 0 0 Oct 31, 2019 #3 abdywgn said: Professional Products 55026: Crosswind Intake Manifold 1500-6500 RPM Range | JEGS Click to expand... Guess I should have put in the ad, I'm running stock serpentine setup so the thermostat housing needs to be in the OE offset location.
mderoy340 Well-Known Member Joined Aug 2, 2012 Messages 2,702 Reaction score 1,633 Location Melbourne FL Rating - 100% 7 0 0 Oct 31, 2019 #4 FYI the M1 I had and sold off a 300hp Magnum crate motor was not off set. I hope this helps.
jos51700 Green Bearing thread connoisseur Joined May 24, 2009 Messages 7,439 Reaction score 3,123 Location Bel-Ray Rating - 100% 7 0 0 Oct 31, 2019 #5 Maybe a dumb question, but are you running EFI or carb?
R RAMVAN96 Member Joined Oct 28, 2019 Messages 16 Reaction score 4 Location Wisconsin Rating - 0% 0 0 0 Oct 31, 2019 #6 jos51700 said: Maybe a dumb question, but are you running EFI or carb? Click to expand... Have decided to go carb for the time being. Someday I may switch to an efi setup. Need an intake with the offset thermostat because I'm keeping the serpentine system on the engine. A centered thermostat won't work as far as I know.
jos51700 Green Bearing thread connoisseur Joined May 24, 2009 Messages 7,439 Reaction score 3,123 Location Bel-Ray Rating - 100% 7 0 0 Oct 31, 2019 #7 The carb m1 has been more scarce than the efi m1. Are you running a/c?
Commando66 She's a beaut Clark! Joined Dec 2, 2007 Messages 2,076 Reaction score 767 Location Mount Vernon, WA Rating - 93.3% 14 1 0 Oct 31, 2019 #8 My extra has the thermostat centered
abdywgn dismantler Joined Jul 30, 2006 Messages 3,714 Reaction score 4,150 Location Darien, Illinois Rating - 100% 5 0 0 Oct 31, 2019 #9 doesn't the Edelbrock Magnum engine have the offset thermostat?
mderoy340 Well-Known Member Joined Aug 2, 2012 Messages 2,702 Reaction score 1,633 Location Melbourne FL Rating - 100% 7 0 0 Nov 1, 2019 #10 abdywgn said: doesn't the Edelbrock Magnum engine have the offset thermostat? Click to expand... Yes Edelbrock Performer RPM Air-Gap Intake Manifolds 7577
