[FOR SALE] 76 Dodge DartLite /6 4 Speed
moparblood
n.y.
parting out dart!
Complete air cleaner to driveshaft
has alum intake/2.5 exhaust manifold
aluminum OD 4 speed trans New clutch
1500. local pickup only
Doors w/glass -125. each
driver fender -100.
clutch pedals- 150.
large bolt pat Disc brake set up -300.
rear wind shield - 100.
rear side glass-35.
steering column w/key-250.
rear bumper assembly w/aluminum inserts brackets -350.
front bench seat- 75.
rear seat - 75.
rear 7 1/4 axle -100.
manual steering box-100.
floor tunnel-100.
4 speed adjuster kit
z bar
shaft rod/boot
fork
ball stud bracket
frame ball stud
reverse light- 200.
tail light panel- 150.
any other parts you can inquire about!
If you get to the point of parting the engine, I would be interested in the exhaust manifold.
Can I get pics of front and rear Bumper Brackets, please?
I haven't seen a welded slant intake in a long time.
I sent you 2 messages earlier today.
Give me a call Phone number removed by staff.
Thanks,
Darren
i'll post pics layer of the brackets.
and get price on linkage for clutch!
Thank you for taking the time to post pics of those brackets. For years, I've pictured the wrong part, and I apologize, that's not what I'm looking for.
I have a 75 Dart sport (still with stock drum brakes). Would the disk brakes be a fairly straightforward bolt-on?
If your car has the small bolt pattern drums, the brakes off the 75 would be the big bolt pattern and be a mismatch for the rear. But it is still a bolt on.
Sorry if this is already posted a million times on the forums, but what's the more surefire way to know if my stock drum brakes have the small versus big bolt pattern? Thanks!
measure the wheel stud from edge to across center of other stud. if its 4' its small bolt pattern 4' 1/2 large.
Every A body built with drums brakes had small bolt pattern. 72 and earlier all the disc brakes were also small bolt too. From 73-76 all V8 A bodies had power disc brakes and slant 6 cars with the power brake option got large bolt discs as well. 73-76 slant 6 cars came with small bolt drums standard
The metal dash frame for my 75 Duster I have the A/C vents under dash if that makes a difference Woodgrain dash face Thanks
I'm still interested in the Large Bolt Pattern disc brakes. My '75 still have the drums on the front, so I'll need just about everything to make the conversion as seamless as possible. I tried PM-ing you, but your inbox looks to be full again. Thanks!
