rustytoolss
Will any of the 4BRL after market Magnum intake manifolds fit and bolt up to the factory AC and brackets The engine and AC will be from a 1995 Dakota 5.2.
NO.. I believe you have to trim the rear A/c mount on the big alt/ac/pulley/ front engine bracket. the pad in which the ac pump sits, the rear mounting points have to be massaged to fit but it can be done.
From what I understand "most of them" it s due to the location change for the thermostat on the factory Keg manifold it's off to the left of the block behind the alt.all magnum intakes...or which one ?
I don't have an engine yet also. But thinking it will be around 1995 5.2 with the serpentine belt system , and may try to reuse the factory AC pump ( if possible) . But will need an intake . Want to avoid using the fuel injection and computer system.Let me start by saying, I dont have any hands on experience with this.....
That being said, it was my understanding the Edelbrock 7577 was a direct fit, with the serpentine belt system including the AC.
The other manifolds ie: speedmaster, etc. has the t-stat where the LA motor does, and works better with the V-Belt drive system.
I plan to use the 7577 myself. Just put a deposit on a 5.9 magnum.....
