ID these engine brackets
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Robbinsville, North Carolina
I need some help to ID these S/B engine brackets. I bought up a couple different pair to install my 360 in and these are what I didn't use.
This is what they look like bolted on a 318. Look close , they are on opposite sides of the block lugs. Is that correct?
Thanks Al. I want to list these for sale later if they are a set.
With that little kick, they look like 340/360 A mounts, otherwise you take up the straight side slack with washers
They are both left (driver)side mounts for a 318. NOT a set. The one with the missing ear is a 67-72 A body. The other is a 318 66-72 B and 70-74 E body.
List them singularly. They still have value if someone is swapping down from a 340/360. Only the left side is different. You might get $15-25 each plus the ride for them
