Linkage ID help!
gliderider06
Delaware
Is my unpainted linkage the 4bbl set?I'm pretty sure it is. I don't want to cut the trans bellcrank down for the tti exhaust to work, if I can cut up the 2bbl set since I have 4 of them. I'm trying to get all the trans linkages hooked up. Small block, 727 trans in a Duster.
Thanks!
There is different width brackets/bell cranks from older vehicals. Kim
Yes, I noticed that. I have wider and some that are narrower.i dont want to cut a 4bbl bellcrank if I can make a 2bbl one work.
Thanks!
