Is my unpainted linkage the 4bbl set?I'm pretty sure it is. I don't want to cut the trans bellcrank down for the tti exhaust to work, if I can cut up the 2bbl set since I have 4 of them. I'm trying to get all the trans linkages hooked up. Small block, 727 trans in a Duster.
Thanks!
Thanks!
