Ford 9inch to 727 driveshaft
dukeboy440
No
For those that have converted to a Ford 9 inch, while running a 727. What U joint are you using or is there in adapter style one that will let you use the 727 shaft and bolt to the 9 In pinion yoke?
Denny's Driveshaft has any of the combination u-joints that you might need. The Ford 9 yoke most likely is a 1330 or 1310, to your 7260 or 7290 driveshaft.
Thanks
Since you will probably need to have your shaft length changed. Have a Ford end on the rear and a Mopar on the front. No need for odd ball conversion joints.
Something you need to BE CAREFUL of with Ford rear ends is the so called "big cap" U joint. That damn near entrapped me. There is very little difference in cap diameter
This page here. There is only 1/16 difference
U-Joint series identification
