Head casting numbers questions
Dodgeguy44
New Member
Bonnyville, Alberta
I have a 1976 Dart Sport 360 (4006830-360-5) with 2.02 valve heads one casting numbered 3418915-F and the other is 34189 5C. Are these the same heads or.......? I have looked through casting lists and haven’t found the second number. Where the 1 should be there is nothing and are F and C different?
The 1 is probably just missing in the casting. Should be the same head.
3418915 - 1970-1972 - 340/360 J head . leak for casting dates - month (a letter) day , year - 70 71 72.. 70 71 was 2.02, 72 was 1.88"
The letters on the end may be batch numbers or even mold groups. Molds and cores wear out from use and are rebuilt and modified as needed.
