Valve cover grommets
InRogue
Winter Park, FL
Okay before I start these are needed for cast aluminum covers, the holes are 1 1/4" but your standard China jobs are loose, these used Holley covers i got had one grommet in the hole (see pix) and it was tight and even looked Mopar type but different. And one know of a good quaity grommet for PVC and breather that are a true 1 1/4".
I had to replace one of them in my magnum 318 and had the awfulest time finding one. I ended up getting one thru the local dodge place it was a mopar part that none of the local parts stores carried. I found all sorts but either the center hole was to big or the od was to small nothing fit it. I cant remember the part number now. But it wasnt the Pcv valve side it was the other one on the drivers side. It went back to the keg. IIRC
