So had to pull my new motor, because the oil pan sprung a leak on the side were I did some welding on it, after starting it for the first time. I replace the oil pan with new one and took out the right angle oil filter adapter and repaced with a straight one because it didn't work well. So I put the motor back in and started it up and now it's leaking around the oil filter, not to mention the the transmission line is now leaking (l must have punctured it on the install), and to add insult to injury the thermostat housing is leaking (why not have all the fluids leak!). So time you have to say WTF!!!!!
