Very cool show and tell. Nice car.
Now we just need a burnout video and/or a track run! LOL!
Speaking of which, have you had it down the strip?
What gears are you running and how does it do for mileage?
3.55 gears, and the OD trans.
I forgot a few things in the video, like subframe connectors, 26inch radiator, headlight relays, GE Nighthawk headlights.
Never had it on a track of any kind because until recent it was 2.73 geared one legger 7.25 rear end.
Runs right at 25mpg in OD, but last time I went to Phoenix I noticed it used less gas than with the 2.73 gears.
I didn't expect an increase in fuel economy because of the hiway RPMs being 500 higher, but coming up the 2,000 feet elevation climb it did better than before.
The lower gears offset the higher R's I guess. (apparently less throttle to do the same speeds.)
Really haven't taken the time to verify any of it for sure yet.
I have whats called a "race app" on my phone that you set to "Ready" and when the GPS of the phone see's the car move it starts timing.
Don't have a clue how accurate it is, but it did tell me it took 7 seconds to go 60 feet walking.
A burnout video could be possible, but these current tires are so sticky (soft compound) that the car seems to just want to take off and not spin a lot.
Hell I don't even know yet if the line lock will hold it anymore.
Really looking forward to getting some cheaper tires so I can play with it more instead of feeling like it could take off across a drainage ditch before I can stop it.
There's no screwing around right now, as once the tires hook you better be pointed in the direction you want to go because that's where you are going like it or not.
Thanks for the comments on it.
Appreciate it.
