Right Stuff gasket maker
Mike69cuda
Mopar Moron
Kansas City
A lot of folks on here talk about this gasket sealer. Which one do you use, the 1 minute or the 90 minute?
I swear by it.. I think you get a little bit more than one minute to deal with it but if it's a hot day and you don't get it on right the first time LOL you'll be scraping it all back off and trying again LOL ask me how I know! LOL but with that said 5 years and nothing leaks.. I might add 5 years of torture and nothing leaks...
If you like to chisel for disassembly use the right stuff. lol
I like Permatex ultra black, it's oil resistant and seals good and easy to remove if needed.
Oh come on, it's not that bad it's like you get what you pay for. if it's a little harder to come off during disassembly that means it's a little harder to leak...
This is what I use...introduced to it several years ago in the aviation industry. Teledyne Continental Motors, came up with it building their engines. Now a Loctite product. Doesn't take set until pressure is applied. Looks and smells like grape jelly. A really good product. I have assembled many engines...no leaks!
646942 TCM GASKET MAKER | Aircraft Spruce
I use Maximum Oil Resistant Black RTV by Permatex also. Never a leak, and pretty easy to take things apart and clean up. On freeze plugs, and T-stats I use Ultimate Grey Permatex RTV.. love the stuff.
How can anything leak it only gets taken out of the garage once a year:poke::D...
I have more miles on my '74 Duster this year than you do on your Duster. More feet of rubber burnt too :D
where are you getting your stuff?...:rolleyes:...
Wow. Expensive. Does it spread and act like silicon when using it?
I use this stuff also. The only problem I ever run into with any gasket maker is me being lazy and not doing a good enough job cleaning the surfaces. Especially on differential housings.
For lack of a better description...it goes on with the consistency of "sticky Vaseline." It doesn't drip or run. An example of its performance...aircraft (most) engine crank cases are two piece, with the crank shaft "sandwiched" between them. The case is held together with a series of bolts, studs and nuts. The two mating surfaces do not use a gasket of the sorts, but a strand of silk thread (same size a common sewing thread) and in the past, brush on "Permatex" was used as a sealant. Now all we use is the 515. I usually apply a small bead of the 515 on the flange or the mating surfaces and spread it evenly with a brush. (acid brush) When actually using a gasket (cork or paper) I'll massage the gaskets with the 515 using my fingers. You don't need a lot on the a gasket, just make sure it has been coated on both sides. Yes, it's a little expensive, but it goes a long way. I'll add one last thing. The 515 is not intended to fill voids in what you are building, it is intended to be used with "well mating surfaces and gaskets." It does not " require a "hammer and chisel" to take it apart.
That is for tight machined surfaces only .015 gap as I read. This is the same stuff we used on Cadillac Northstar crankcase's, It is the best I used for tight straight surfaces but wont work on most parts of a Mopar engine.
Other stuff I found that works great is ThreeBond Products.
1215 is the best in my opinion, it's the same as DucatiBond 1215, it has about 15 minute work time. I used it on the side cover on me 833 and it never leaked. It also cleaned up real nice after years in a 2 stroke case. It is the same as 1211 but has longer set up time.
https://www.amazon.com/dp/B073K1919W/?tag=fabo03-20
I just started using “Indian Head” gasket sealer a few years ago and love it. Great for holding intake gasket on the head while I’m getting ready to put the intake on. If your transmission gasket is all folded up from being in the box a little of this holds it nice and flat. The longer you have it, the more you use it.
