I recently installed a 440 with Indy Heads with 2 inch TTI headers..After installing it I find out I need to ding the header tube for the steering coupler to clear..It's a major pain in the *** to have to drive back the torsion bar, unbolt the header, unbolt the steering box and fish out the starter to remove the header..Now I am looking forward putting all this back together after dinging my header in the spot that needs dinging..
Now the word of advice..If you plan on installing a big block in your A body definitely go with a low deck block and use 1 3/4 headers..It will save you a lot of grief on down the road..There are areas I'd give 500 bucks to have an extra 1/4 of an inch clearance..When the time comes to have to pull the 440 out of my Demon you can bet your sweet *** that a low deck is going back in ( I've already purchased 2 400 blocks for that purpose) along with 1 3/4 TTI's.....
