Yup. It's very straight forward. Remove bolts, take old pump off, put new one on. No need to worry with the distributor since all you're doing is engaging the oil pump drive rod. It's a hex rod that fits into the hex drive on the pump. You'll see. Real self explanatory. I "WOULD" go ahead and prime the pump before putting it on. That will require I "think" it's a 1/4" make hex. Might be 5/16" I cannot remember. Whichever, I just get the right size allen wrench, cut the short 90 off it engage it in a cordless drill and have at it. Fill the filter up, screw it on the pump and pour the coals to the drill. Looking at the hex drive on the pump, it turns CCW. DO it in a 5 gallon bucket, because it's gonna come squirtin out the engine side of the pump. Once that's done, slap it on and go.
