cudamark
Possibly, but, it only takes another 10 seconds to pull it at that point, so, why would that be an issue?I’ve done column work on b bodies. Is it pretty simple to switch out the ignition harness on a 73 Dart ? As far as pulling it out and replacing it. I assume it can replaced without removing the key lock correct ?
