74 360 dart sport
I bought my 1974 dodge dart 360 sport 4 speed and some parts came in a box so I do not know what the 2 wedges and big thick nut is for and where do they go thanks
I think I have seen brake lines screwed into that big nut. Is ur car a 360 wedge. Lol. KimI bought my 1974 dodge dart 360 sport 4 speed and some parts came in a box so I do not know what the 2 wedges and big thick nut is for and where do they go thanks
LOL. Make sure they are for a different make. Sell a Dodge and put in some Ford and GM parts. Make sure that FOMOCO and GM are not present. Also, toss in a few Lowes parts.next time i sell a car, i'm going to put a box of unrelated stuff in the trunk to keep the next owner "busy"...
Thank you that is where it goesThe big nut is probably the nut that holds the brake booster brace to the firewall.
Wow, I actually have a picture that shows it.
That’s not the same nut. KimThe big nut is probably the nut that holds the brake booster brace to the firewall.
Chevy junk, stripped bolts and stuff.next time i sell a car, i'm going to put a box of unrelated stuff in the trunk to keep the next owner "busy"...
your repeating your selfChevy junk...
Thank you so much mopar mike that is where I put it I was joking when I posted it in the plug hole just a little humorCircled in red. The nut goes behind the lower booster brace. Its a large hex nut (about 3/4") with small threads (5/16 I think). It gives the brace more surface are so the sheet metal does not crack. Without these two braces that booster really moves around.
It goes just to the left of the oval hole (used for manual trans linkage, plugged for auto)
Pic is of my unmolested 73 340 dart.
