replicaracer43
Grumpy Old Man
- Joined
- Oct 10, 2008
- Messages
- 6,051
- Reaction score
- 7,867
I'm pretty sure the last one we did, you use the magnum pan with the one peice gasket, there is no cutting or splicing of anything.Something else to note when using a Magnum oil pan with an LA timing cover: you'll have to cut part of the one piece pan gasket that goes under the timing cover, use the LA oil pan to timing cover gasket and seal the seams between the two.
