moparwingnut
Member
hi all! new to the mopar small-block world (have a bigblock too)...just bought a '72 Duster, (H-code car, 9-17-71)
...trying to verify the engine numbers but other than correct 340LA stamping, there doesnt seem to be any vin number or other info in the usual places (left side below cyl head/anywhere under the date code)
...and the date stamping is also confusing as there are only 2 digits!? (25/72)
the car runs strong, and i want to determine:
is it a numbers matching engine?
is it a forged crank?
is it 8.5:1 compression ratio?
there's an edelbrock intake and holley carb on it..so someone has likely been in there!
***EDIT***
..i just realized i'm starting to see some numbers on the pad under the cylinder head...whats the best way to reveal them?
...whats up with my date code?
...is there another location to look for vin numbers?
please help any way you can!
cheers
jeff in ontario
***EDIT***
cheers
jeff in ontario
