Hallzy
Align bore an hone zero deck the block, clearance the cylinder wLls for the rods with the 4" stroke , forged "H" rods and 10.5:1 pistons 4.040 bore ,w valve relief, forged steel crank, monster eq 2.02 intake magnum heads(dual pattern intake drilled) cnc runners and match intake. Melling HV oil pump, billet distributor, 4bbl holly efi live tbi. Adj Roller rockers on 3/8" studs, hd springs w dampers. roller lifters chain & cam w/ .505 in lift 114in/112ex 110 sep. SS valves 3 angle hardened seats polished chamber. Cradle the main journals and a splash shield. Port presurized oil onto all cam bearings and cross port coolant to back of head,
