Got the rear disc brakes for my Duster
AndyF
Oregon
Everything has been on back order this summer but I did finally get the 13 inch rotor kit from Baer for my Duster project. Also got the 17 inch Weld wheels and the 315/50-17 tires. So once my new 9 inch rear end shows up I'll be able to get everything bolted in place. Might even be able to drive it this Fall if the weather holds.
any plans for a portioning valve, or are you going to see how it does first?
Those tires don't look like they play well in the rain. I know the "back order"feeling , just got my GTS running and I'm waiting on a radiator shroud again since I was sent the wrong one.
Is this the Duster you were installing Viper disc’s on the front?
