65 Dart Rusted front passenger wheel well.
Stumpy
WA
Found some rust on the 1965 Dart. I didn’t see because it was sort of hidden. I don’t know what they are called but the piece that attaches to the inside right front fender in the wheel well under the hood hinge right under the antenna is rusted out and needs replacing. The rest of the fender inside is perfectly rust free. They look like they come apart. Never had to do it before. I imagine I could remove the fender and attach a replacement if I can source one. Advice?
They are not repopped for that year and model. Used is the only way to go. A wanted thread is the place to start here on FABO.
What is the name for that part?
I don’t know if you can get an idea from this but this is looking aft and up from right wheel well. You can see the rust hole.
Thanks. Looks that vert shield on the firewall side.
