dartfreak75
Restore it, Dont part it!
Yes by the card. Straight upHow did you install the cam? By the cam card or something different?
The cam has 4 degrees advance when installed straight up or dot to dotStraight up is dot to dot. That's not what the card says.
Yea it was degreed don't you remember the whole thing with the timing chain?The cam card on that says 108 ICL. That's 4 degrees advanced. If you put it in dot to dot, it might not be right. Did you degree it?
LolVaguely. Man I caint remember my name some days.
I have a small airport near me. Self serve. I buy five or ten gallons per trip, and mix in a gallon or three when i take my brackett car (10.75cr, iron heads)to the track. 100Low Lead avgas, for about the same price as california 91 10% cat pee.We have a small airport nearby wonder if they sell fuel
Man I hope so. I'm looking forward to the tuning process iv always enjoyed thatOne thing's for sure. When you get that beeotch all dialed in, it oughtta be strong.
Where do you get that from?If it was mine, I would have some race gas on hand for startup and break in. not unleaded, either. 114 leaded. It will appreciate that.
We have a local oreilly i will look into thatMost big box parts stores can get it. I think O'Reilly can get VP Racing fuel.
If guys keep their small airplanes there it will more than likely have 100LLWe have a small airport nearby wonder if they sell fuel
I don't know if they have fuel there its not a big airport its mountain empire airport i think is the name of it. Its right there where I work about 3 miles away. On clear nights you can see the airport lights in the sky from work.If guys keep their small airplanes there it will more than likely have 100LL
Yup. LOLI don't know if they have fuel there its not a big airport its mountain empire airport i think is the name of it. Its right there where I work about 3 miles away. On clear nights you can see the airport lights in the sky from work.
Yea that's it. So by full service does that mean they will sell to anyone? Or you gotta have a plane?
Not necessarily. Ours used to be full serve but they would come out to the pump and fill you up a 25 gallon drum in the back of your truck or something. Then it went self-serve at the pump. Call em. I don't think they'll have a problem selling it to you.Yea that's it. So by full service does that mean they will sell to anyone? Or you gotta have a plane?
Haha. Yea nobody is certainly suggesting to run it straight. Just a little mix. And to stay away from that dinosaur piss they sell at the stations now.Airplane fuel to brake in a mild 360??? That's a bit drastic IMO. Go get a can of your nearest 93 and fire it up. This isn't rocket surgery.
Cash is king ! Just take your cans and jugs, show up . I'd planned on calling ahead. There are at least 3(these I'm aware of) small airports within 20 miles of me . A somewhat larger one at the 40 mile mark,Yea that's it. So by full service does that mean they will sell to anyone? Or you gotta have a plane?
I think i would be more concerned about octane than ethanol.? Yay or Nay .? If your compression is up ,9.5 or more and i wouldn't want to have to give up any timing advance either . Id give up compression before timing advance , according to my modest. ?knowledge? understand of the overall .I went and got some non ethanol 89 today i think it will be ok. Id rather not put ethanol in it rigth now since its not gonna be driven atm. Once im driving it and i can keep a steady flow of fuel i wont mind running premium with ethanol. Iv seen what ethanol fuel does when it sets inside a carb. Its not pretty.
