Cruisingram
In a year or so, will get a crate motor, nothing too fancy, CM rings, good rod and crank bolts, couple other things- this is NOT going to be a real hot rod motor getting big HP out of it- I am designing it to do two things- reasonable power, stay in tune despite bit altitude changes. With that in mind, I am going to do a super mild turbo build- I have a Neon turbo I will use, shooting from 4psi no higher than 8. This will keep the same pressure at any altitude - kinda what turbos were invented for in the first place. I am seriously considering EFI, but may just stick with a 2bl carb. So the first two parts I want to collect if it is available- the best exhaust manifold for a turbo, and a good 2bl intake manifold. Suggestions?
