70Sbird
Possessed by Demons
As soon as I get some time (probably near the Holidays) I'll swap on my new oil pan and see how it all fits!
That's AWESOME!
No complicated Oil filter fiascos and a WORKING A/C compressor on our A-Body Hemi swaps! This is a Big deal!
It would be great to see the clearance on both sides with the K-frame installed.
So just to make sure I am following, you DID go with a /6 K member, not the original V8 K member?
Is it common knowledge you can not have OEM power steering, or AC if doing this swap?
I’m just starting to look into this, but I have a 74, V8 Dart Sport for this project. But my wish list is AC, power steering, power brakes. (In that order). Can I do this with my existing K member? Curious, what is a fair price for a new 5.7 Hemi?
@70Sbird, what drove you to buy the AC expansion kit? You needed a compressor, or you needed a DIFFERENT compressor?
I'm in Central Illinois, near Peoria. The only slant six K frame I had was the one that came out of my 71 Demon....I also have a couple of V8 K frames that I bought for this swap, both pad and spool mount that are now just taking space up in my basement!Where you located @70Sbird ? if you have spare /6 K laying about lemme know. I have a couple v8 K's
I cant say much about fitting the 3G into the Early A bodies, but I had a 340 in my 63 Valiant and I know that it was narrower than the later A bodies. Here is a pic of the engine in my Demon on one of my mock ups. It's tighter than I thought it would be on the passenger side for sure. The drivers side looks great, but the column isn't in there yet either.Man Will this work with the early A slant 6 frame?![]()
Do you think this will work with the factory manual steering boxOk, one pic didn't go, here are the pics of the K frame "clearancing", and everything bolted in place including the Borgeson steering box
I talk to Randy too. He told me the same thing, which I'm not doing. To go that route could be close to $5000 on top of your build. With some thinking outside the box. It can be done.I spoke with Bouchillon Performance and at their recommendation bought the QA1 Tubular K-Member for clearance. I'm strongly considering ordering the Holley mid-mount accessory kit as part of our fitment tests. The shop I'm working with has a few other A-bodies in pipeline to do Gen 3 swaps. Any additional info that I glean as part of this effort will be shared!
GoldSwinger, If that Holley mid mount front accessory drive with the Alternator, P/S pump and A/C compressor setup would have been available a year earlier I would have bought it and saved myself a bunch of pain!I spoke with Bouchillon Performance and at their recommendation bought the QA1 Tubular K-Member for clearance. I'm strongly considering ordering the Holley mid-mount accessory kit as part of our fitment tests. The shop I'm working with has a few other A-bodies in pipeline to do Gen 3 swaps. Any additional info that I glean as part of this effort will be shared!
@70Sbird What Radiator setup is that? I'm on the hunt for one now and don't want to run a stock plastic rad for a late model car.
I used a Northern Radiator # 205199 and their fan/shroud assembly #Z40112. I'm happy with the fit and appearance, it seems like a well built unit. I bought it from Yogi's and the whole assembly was was around $625.@70Sbird What Radiator setup is that? I'm on the hunt for one now and don't want to run a stock plastic rad for a late model car.
