He didn’t give you the duration @.200” on that lobe by chance did he?sorry it took so long to get back to you as my notes were in the shop
106 centerline. I hope that helps.
He may not be experiencing lifter failure. He is old school, and only uses new old stock or USA made lifters as far as I know. I have not experienced lifter failure, but I don't buy cheap cams, cheap lifters, or the latest rage in fast lift profiles, very light oil, and high spring pressures. All of which, I believe contributes to premature cam failure.
No biggie, I just remember that particular grind from some books I haveHe will give you the @.200 number if you ask him.
Oh I think you know more than you let on! I was just curious about that particular lobe as I had a custom cam ground by Isky a few years ago, (but changed plans and sold it not long after) that was very similar in specs, a hyd 286/[email protected]” with .500” on a 106LSA (basically a lift limit circle track cam) a lobe down in their list that had a little bit more “area under the curve” than their typical hyd lobes.honestly I know nothing about cams and only look at cam centerline, .050 duration, total duration, and lift. After that if buying a new cam I trust those I trust. I have been very lucky using the figures above buying used cams (roller only) over the years as they seem to work pretty good for me.
I don't know if that is a fair assessment, the website is pretty comprehensive and very easy to navigate IMO.
That's NOT Jim's website, that's 4 Seconds Flat's site. They rep Racer Brown cams. Splitting hairs, 4 Seconds Flat is in Oregon, Racer Brown is in Baltimore. Minor details. They're both good to deal with.
Don loves to BS too. Lol. I usually get my cosmetic gaskets from Don. I tell him the bore and he recommends a bore size. Prices are more than fair.
