furrystump
- Joined
- Nov 13, 2004
- Messages
- 2,126
- Reaction score
- 1,722
Oh ran drag week in 2019 with it. Average 12.0 with it because it was HOT! 90+ degrees
3:55 and a gear vendor od
Am I the only one wondering why you would want a 408 in a motor home ?
Why not just build a nice 360 with an RV cam ?
Save the 408 for a street car.
To each his own I guess. I would be much more likely to do the opposite and build a hot 360 for a car. Pulling a heavy load is all about torque at low rpm. Stroker does that better than any 360 ever could.
If this were an RV that was going to be used 2 or 3 weekends a year like most, I probably would settle. I plan on several long extended trips though, for months at a time traveling most of this great country. I even plan to run it all the way up to Alaska-during the summer of course.
The question you brought up, was longevity.
My money would be on a stock 360 outlasting a 408
in everyday use. Especially in a motor home. My .02
That Stroker should live as long as anything else if you keep the oil clean, the coolant temps in check, don’t beat it to death with detonation and you don’t shift it at 7000 on every gear change.
I can’t see why 100k isn’t expected. Keep the piston speed down, control the temp pulling long hills (most guys don’t think they should ever have to pull the shift handle off the D and the exhaust temps soar like an Eagle and that kills parts) and that thing should live like anything else.
I think...... the thinking is the rod ratio forcing the piston harder on the wall. IDK for sure. I think a 410 for a motor home is OK. More low end torque to move a way heavier vehicle down the road with ease. A Diesel engine would be great but a possible huge PIA to swap over? IDK... I do see an easy route of engine family swapping to be the quickest route. Adding the extra cubic inches is a slight cost over a stout stock rebuild & worth the cost in terms of power return vs dollars spent.How do you figure that? That doesn’t make sense to me.
Just thinking out loud here. I should have stated I have no experience between the two.
I think we could all agree that a fresh 360 will be a big improvement over the tired 318.
Got to take into account the price to build a 408 verse the price of a 360 build. I'm thinking the 408 will/should cost much more, unless you already have the necessary parts to build a stroker.
F**k it....Go big or go home. Put a bad boy 408 in that Winabego !!!!!!!!!!
This will be an interesting project for sure! If it's not a huge Class A, the 408 should be plenty adequate for it unless you will be pulling a heavy toad behind it. Got any pics of the beast?
Just thinking out loud here. I should have stated I have no experience in longetevity between the two.
These are older from the previous owner. She has been sitting for 3 years and needs a bath now.View attachment 1715690012 View attachment 1715690013 View attachment 1715690014
That is a great looking Travco! I'd say it probably has 4.56 or 4.88 gears in it, so an OD will be a nice addition to it. My wife and I have a permanent site in Myrtle Beach Travel Park, and I heard something coming down the road by our place a few years ago...and it sounded very healthy. I walked to the front door to look out....and it was a Travco similar to yours. I looked them up a few days later and stopped to talk, and it was some folks from NY, on a big road trip like you're planning. It had a 440 in it that sounded awesome. The dude said they had been everywhere with it, and he didn't really mind buying what extra gas it might burn because there wasn't a 100K payment book attached to it....lol. If you cross the Rockies, you may have to take your time, but a 408ish stroker should do just fine.
That’s why I asked. I didn’t know if rod angle, piston speed, both or some other geometry thing caused you concern.
Well after seeing this land yacht, I'm thinking a 440 would be a better choice.
Nice , I know where one of those old Dodges like u have pictured is up in Franklin NC its just setting there rotting ,
