Has anyone ran one long term and put a bunch of miles on one? I bought an RV and keep going back and forth on whether or not to do a small block stroker or big block.
Yep, same rod/stroke ratio as 454 Chevrolet which has been in thousands of motor homes over the years.I’ve had my 416” for 10 years.
Mopar SB’s have tall decks. 4” strokers have rod angles like other normal production motors.
What does the RV have in it now?
Built right last forever
How many miles have you put on it though? Trying to find anyone that has a high mile example.
Do you have an example you care to share?
It has a 318, but that doesn't matter much as I will be changing everything anyways. Not going to hit the road with stuff that is 50 years old. Radiator, and accesories will all be replaced. Trans will be 518 but I have big block adapter on the shelf.
Don't throw 727 away it most likely has 4 gear front and rear planetary's
if original .
Just like you would do a good rebuild on any other motor.
poor quality work on a 318 will give you the same poor quality results on a stroker.
I think you're asking good questions, and I think rod angles are acceptable I don't believe that 454 are known for their exceptional long lifespan but my biggest concern with the stroker Dynamics is piston speed which can be overcome with quality internal parts. But it seems like for your application that would not come into play at all. I don't see why it wouldn't make an excellent RV power pack. If it was me I would use a light reciprocating unit quality cast crank such as scat some good hyper Pistons and you should be good to go .
I meant an example of a 408 with some miles on it. I know most are built for toys or racing so there wouldn't be many examples, but I would like to know of at least one real world deal. The engine will be built right regardless of what it is.
My personal 408 has been in my dart, making 600 HP, for probably 8 or 9 years.Maybe ask @Johnny Mac , he should be able to give you an idea of how many 408s fail under warranty
good pointsI think if it was me and you had the adaptor I’d build a 440 for it. Strokers last decently but the kits have short pistons and narrow rings and I’d rather have a tall piston with thick rings for a motor home.
Is your RV a Van nosed Class B or Class C? If so, since you say it has a 318 in it now, you will have a tough time getting a big block to fit. The doghouse between the seats is bigger on factory big block vans....plus, whoever sits in the passenger seat gets their left leg roasted by the headers or exhaust manifold. If you can get the same warranty from Blue Print Engines for a 408 to use in an RV, I don't know how you could beat that deal. Just my 2 cents.
in our BluePrint Mopar 408's they are honesty some of the happiest customers i hear from. Last one i saw fail was due to a customer using oil filters that were decomposed. We changed our mopars to forged pistons/rods probably 5+ years ago. Can't say any BPE faulted failures come to mind. especially with the new roller cam setups. they dyno SOOO much cleaner than the LA's did.
